Warning - this is gross - but a serious problem
I also posted this in Ask the Doc, but thought I would try here too.
I have an area where the gum is swollen and it is painful. When I push on it, some clear/cloudy/slightly yellow fluid comes out and it has an awful smell (i know - its digusting) and it is causing bad breath.
My gums have swollen before due to irriation from my braces, but I have never had the fluid and it usually goes away in a day or so. Also, this area is behind my very last molar on the bottom (where my wisdom teeth would be) and there isn't a molar band or any brackets on that tooth, so I have a feeling its not because of the braces.
This is the 2nd day of this problem and it is really worrying me. I just went to the dentist a couple of weeks ago, they didn't say anything about gum disease. I have been rinsing with mouth wash and brusing regularly, but it just make the fluid smell mint-flavored and still really gross.
Has anyone else ever experienced this? I wonder if this is common? Please help. Thanks
![Image](http://tickers.TickerFactory.com/ezt/d/4;10726;103/st/20070416/e/Braces+get+taken+off%21/dt/-1/k/7d30/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10732;130/st/20050803/e/Braces+got+put+on/dt/-1/k/afec/event.png)
This is most definitely an infection. Swelling, discharge and bad smell, are good signs it's an infection. How's your lymph node feeling on that side of your neck? if it's swollen and tender or painful, you have an infection.
I have had this happen to me before. A potato chip got wedgend between my back molar and gum and became infected.
My advice would be to immediately start gargling with 50% water and 50% hydrogen peroxide. If you have a water pik, use it. Use a toothbrush and try to gently clean the area with the water/hydrogen peroxide solution. gargle 4-5x times a day.
If you dont have hydrogen peroxide, buy yourself some listerine, original seems to work best on this. It may burn but it seriously kills germs.
You should be able to take care of it this way, if it's a mild infection.
If it doesn't get better or you develop more symptoms, like fever and very painful lymph nodes, get your butt to the doctor or dentist asap! You might need antibiotics. Mouth infections, specially gum infections can lead to serious illness.
Also gargle more often with Listerine or Biotene. Even when your mouth feels healthy.
I had that problem once years ago and my dentist said it was a "pocket" of gum where my wisdom teeth had been removed, which had got full of gunk and got infected.
You will probably need antibiotics and to have the infected part cleaned out. I wouldn't try and treat it at home, although you can use salt rinses and peroxide in the meantime, call your dentist and get it looked at.
Good thing you noticed it -- infection can become serious if not treated in timeronni wrote:Yep - its an infection from food being logged under the gum. No antibiotics though, he just cleaned it out with an antibactieral rinse and put me on a intense cleansing routine.
I hope it starts to heal soon!
