Lower incisors --movement & retention
Just a couple of questions...
1) What kind of experiences have you all had with movement of your lower incisors (ie, bottom front teeth)? Have you found that movement tends to come more easily when compared to your upper teeth, or that they took longer to move in comparison?
2) Is it common practice to have a wire cemented onto the inside of your incisors once braces are removed (sort of a permanent retainer)?
- jennielee81
My lowers moved quite a bit slower than my uppers. I even remember the assistant asking me why they were so slow (she was being silly of course).
My ortho cements the wire on the lingual side of the lower incisors as a permanent retainer.
I don't know why he does this instead of a removable Hawley on the bottom, maybe better compliance by the patient?
Good luck to you!
Good luck to you!
