Questions - elastics, medications
Ok, under the theory of no stupid questions....
I've just been in for an adjustment and got elastics. They are a triange pattern on both sides, and I only need to wear them while sleeping. But it turns out that they hurt so much that there isn't much actual sleeping happening. My usual pain meds don't seem to be helping much - barely even taking the edge off. So my question - does it get better (like the new wires do) and if so how long becuase i'm a little sleep deprived right now, or is this something that needs to be talked about with my ortho?
And on a totally separate note, any suggestions for how to take Tums/Rolaids that need to be chewed but there's no way that I can chew a hard tablet - soup is about my limit right now? Will they work the same if I just swallowed them whole? Turns out the doctor recommended that I take these with Aleve.
Thanks for the help!
Sorry, I don't know about elastics.
As for the Tums, as an alternative, could you take something liquid like Pepto? Maybe if you talked to your Dr. and explained the situation s/he could recommend something different.
Hope you're feeling better soon
![Image](http://tickers.TickerFactory.com/ezt/d/4;36;2/st/20060921/e/I+got+my+braces+on/k/1f61/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;89/st/20081218/e/I+got+my+braces+off/k/d518/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/2;9;442/st/20071211/n/My+Little+Man/k/b1e4/age.png)
Was braced for all 9 months of my pregnancy and managed to keep fresh elastics on during all 26 hours of labor!!
- jennielee81
Yes, elastics do get better. I take midol for the night time pain as it has something in it (plus Tylenol) that makes me VERY SLEEPY.
I would take a liquid stomach medicine (Pepto Bismol) or the Tums that dissolve (I think they're called "smooth dissolve"). You can just let them melt in your mouth. Read the labels at the drug store to be sure.
My elastics are in 24/7 except for 1 that's only nighttime. After a few days they do stop hurting.
Try taking a Benedryl tablet with your pain medication or a Tylenol PM at bedtime and you should sleep just fine. Don't do it more than a few nights in a row so you don't get used to the drug indused sleep. Should help for a few nights anyway!!
Good luck!!!
![Laughing :lol:](./images/smilies/icon_lol.gif)
Good luck!!!
I've had triangle configurations for a week now that have to be in 24/7. I didn't have too much pain to begin with, but it's gotten much better as the days go on. For instance, I've started munching on things like pretzles again! Hang in there, it gets better! As far as sleeping goes, Tylenol PM might help, but it can be habit-forming. There's an herbal pill called Melatonin you can buy almost anywhere that is a sleep aid. It's a naturally occuring enzyme in your body so it's non-habit forming, and you don't get the "hang-over" commonly associated with drugs like Tylenol PM. I take it sometimes and it just helps you gently ease into sleep; won't make you dopey or drugged-up feeling at all.
Hopefully the pain will stop soon and you won't need anything to help you sleep!
~jlb~
Braced 5/19/06 - Full Metal Mouth!
Went topless 07/27/07!
Totally NAKED 08/30/07!
See my braces story with lots of pics here:
http://www.archwired.com/phpbb2/viewtop ... 2806#92806
- jennielee81
Good point Jillianleab about the benefits of Melatonin. I use it a lot and it is fantastic, gentle lull to sleep rather than a sleepy feeling. I do, however, occasionally need a "GO TO SLEEP NOW" hit of something.There's an herbal pill called Melatonin you can buy almost anywhere that is a sleep aid. It's a naturally occuring enzyme in your body so it's non-habit forming, and you don't get the "hang-over" commonly associated with drugs like Tylenol PM. I take it sometimes and it just helps you gently ease into sleep; won't make you dopey or drugged-up feeling at all.
![Gavel :gavel:](./images/smilies/gavel.gif)
Nice to hear from another Melatonin fan! I thougth I was alone
![Paperbag :paperbag:](./images/smilies/paperbag_125.gif)
Oh man
I do know exactly how you feel. It does get better. For me it took about a 5-7 days. I've had elastics for a few weeks now and no more pain but I did not sleep for several days. Well I slept for like a total of 2-3 hrs each night. Tylenol/Ibuprofen did NOT work at all. I ended up taking some leftover Vicadin I had left from my extractions. It did help a lot the only bad thing was that it knocked me out and it caused me to suddenly snap my mouth shut really hard through the night , so that caused me to jump and sit up in so much pain. I ended up sleeping with a washcloth in the side of my mouth so I could not clench my teeth at night.
I feel completely fine now, it does get much,much better.
Gennel
I think the reason I was in so much pain is because I was put in heavy/strength elastics for the first time
![Sad :(](./images/smilies/icon_sad.gif)
Gennel
Alternate Idea
Well, this deviates from your dentist's plan, but seeing as every1 replied that it does get better, and I agree with them from my experience w/ the same config.... I suggest that you wear them in the day and take them off in the night, so you are wearing them for the same amount of time, just until you get used to them, then wear them in the night. It will save you the sleepless nights.
Sounds like my old jobIt's not like it's every day, mind you.
/sorry to threadjack!
~jlb~
Thanks for all the suggestions - I live in hope that it will get better. I think last night was 5 hours straight, so it is gradual. Then I moved and teeth banged together and that was the end of that. The washcloth idea is a good one - I was thinking maybe cotton balls but that sounds better.
And I also want to work in a place where you can have beer bottles close at hand!!!
