I remember seeing my brackets for the first time when the ortho told me to go rinse after putting these things on and I almost cried. I remember thinking they were way to low on my teeth.
I didn't think to ask why because I know they know what they are doing.
My brackets are on the lower halfs of my teeth. The bottoms of the brackets are very close to the bottoms edges of my teeth.
I do have a over bite and wonder if this has anything to do with it?
I see most everyone has the brackets smack dab in the middle of their tooth...?
Whay are my brackets on the lowes part of my teeth?
I also started with a mild overbite and my ceramic brackets are extremely low on my top teeth. I have always been afraid that they will snap off. I can't bite into anything ...not even a slice of toast!!! As a matter of fact, even my dentist remarked to me that he had never seen brackets so low on anyone's teeth before. Not to worry....my ortho obviously knows what he is doing because my teeth are looking great! He did mention that he may reposition them in the finishing stages, so I'll have to wait and see.
![Image](http://tickers.TickerFactory.com/ezt/d/4;10719;122/st/20070123/e/Braces+Off/k/a2e9/event.png)
I swore up and down my bottom brackets were attached to my gums, they were so low. I asked why and they said to broaden my arch and also that I wouldn't bite down on them when I chewed.My tops are what you call in the normal position. Doc said he would move them later if need be.
Braces on 9/01/2006- Braces off 4/14/08
