Have you heard of this
At my initial consultation my Ortho's assistant were saying that they do not put brackets on the back teeth. What does that mean exactly? I realize that I have a lot of questions for them at my next appt.? Is this a good or bad thing?
Re: Have you heard of this
Hello! I don't have brackets on the back of my teeth either. I from pics of seen on this site, it's fairly common. Hope that eases your mind!
XOXO
GemGal
XOXO
GemGal
Hi dymond25!
My upper 2nd molars aren't banded but my lower 2nd molars are... so even there are lots of possibilities, as Meryaten has said, your ortho may band the back teeth, he may not include them at all, or he may only include some!
Hope this helps.
Hope this helps.
Banded 22 June 2006.
Debanded 24 July 2007.
Loving it!
Loving it!
I am no doctor and I can't even recall where I heard this, so take it with a grain of salt. I read/heard that the very back molars tend to "go along for the ride" with the teeth immediately in front of them. If that is true, it would explain not bracketing the back molars.
Expander in 8/9/06
Lowers on 11/30/06
Expander #2 - 6/27/2007
Lowers on 11/30/06
I've been braced for 7 months now and at my next appointment in November, my ortho said to plan for a 45 minute treatment time since he'll be placing brackets on my back teeth.
You're right though, I'm sure flossing will take longer, but I DO believe that these brackets will be necessary.
I've noticed that the molars WITHOUT the brackets are NOT AT ALL in alignment with the rest of my arch. I'm sure that will be fixed.
