Bite plates
windsbud
Bite plates
#1 Post by windsbud »
I just got braces put on my upper teeth 2 days ago and have a bite plate on the bottom. If anybody has one, have you had any discomfort with the bottom of your tongue getting irritated? Any helpful suggestions on what I can use to soothe it? I know I can use wax for the bracket irritation, but that cant be used for this irritation. Thanks all.
HeadgearJoe
#2 Post by HeadgearJoe »
good morning , yea been there done upper an lower bitesplint, an yes they are something to get use to at first , they scrap an rub you raw for a few days , they will get smootherrrrr they more you wear it a get a bit of wear on them , are you having to eat with yours inplace like most of us had to , hope this helps( hgjoe)
braces off 1/31/08 wearing bonded retainers with a nightsplint, will get removable hawleys 2/21/08
