Elastics aren't working
Hey guys. I have a little problem... i dont think my elastics are working. I change them every 24 hours and as the day goes by they get thinner due to the stretch. However for the past few days they have remained thicker and not thinned at all. I haven't seen progress in my teeth either. This might seem like a stupid question, but i dont think the elastics are working.. any advice?
![Image](http://tickers.TickerFactory.com/ezt/d/4;31;101/st/20060117/e/braces+put+on/dt/5/k/1811/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;40;2/st/20070417/e/9th+adjustment/dt/4/k/86f5/event.png)
You only change them every 24 hours? I've been wearing elastics for the past 10 months, and my Ortho told me to change them about 3 times a day; but to tell you the truth, I probably change them about 4 times a day. I get 4 bags every 6 or 7 weeks, but usually only use 3 bags. Anyway, they work for me, I'm on them for a slight open bite and they worked great.
- jennielee81
It has taken me 6 months in elastics to move my upper arch just 3 1/2 mm. Elastics don't work fast...how long have you had them?
Also, don't judge whether they're working on how thin the elastics are getting. Let your ortho decide if they are working.
I change mine 3 to 4 times a day.
Keep on using them!!!!!!!
