I can't get to grips with the search thingy!! So sorry if this has been asked! On my first adjustment i'm getting metal ties! What are they and do they not stain???
I've been sooo good but my ceramics don't look brand new anymore (even though they look the same in pictures and everyone tells me they look good) what other ligs don't stain as much?
Ta people
What are metal ties?
23rd June - First Consultation at ortho
24 July - Second Consultation - Decide on top braces
29 August - Decide on top and bottom braces.
Tops go on 26th Sept and bottoms 2-3 months after
I've just had wire ties put on a couple of teeth - the stubborn ones that need the most work. The rest have standard ligs. So I presume that wire ties are a bit stronger in holding the bracket against the arch wire?
Re the staining: I have cermics on top six, and I had clear ligs initially and they went really yellow. Then I had smoke colour which looked good for about a day then they went green. Now I've had white ones put on which are quite flouresent. I stupidly ate some curry about half an hour later and they went flouro yellow -nice! We tested them in the dark last night to see if they'd glow. They didn't though which was disappointing!
I'm definitely going to get silver ligs next time!
32yr old Kiwi
Braces on 10 August 06
1st adjustment 21 Sept 06
2nd adjustment 6 Nov 06
Surgery in a year
Expected treatment time: 24 months
My ortho uses wire ties only on the teeth that need to be rotated or turned. They seem to make those teeth a lot more sensitive for the first couple of days because not only are those teeth moving, they're also twisting. I hate when the ortho assistant twists the wire ties tight, but as soon as it's over with I'm okay again! My ortho always puts ligs over the wire ties so that all of the brackets look to same.
Debanding: 12/18/07!!! Yay!!!!!
Front Teeth Bracketed 7/25/2006
Back Teeth Banded 7/18/2006
Inspire Ice Uppers/front 8 w/ metal lowers
Treatment time: 19 - 26 mos.
Wire ties do not stain at all. If you get white, they will be beautiful with ceramics. If you get metal, they will be a bit more noticeable while on ceramics. I like the white myself...if you have metal brackets they will use the metal.
They can be very tight when adjusted but the ortho has great control over an individual tooth, for instance if you needed a tooth to be very loosely tied, it can be done. After a few adjustments I didn't really feel as much discomfort when they were retied during an archwire change. You will want to check before you leave the chair for any sharp points so the tech can push those in for you.
Good luck with your braces journey.
The flouro-ness has toned down now after lots of cleans so now the originally white ligs are a cream colour which looks good with the ceramics as they are close to my teeth colour. If I step back from the mirror, all I see if the archwire. If they stay like this (and i don't eat any more yellow curry powder) I'll be happy.
32yr old Kiwi
Surgery in a year
