Does this make sense?
Yesterday I was fit for my retainer . I get my braces off Nov. 15th . They arent perfect. I will definately be seeking further orthodontic treatment later. But I cant complain. They are being done for free. Anyways my question is. My ortho fitted me for my retainer yesterday and than put another powerchain across my front teeth. I can feel them shifting more. My teeth are SORE. So you would think the retainer wouldnt fit when he actually puts it in in 3 weeks?! Any comments?
BrandiJeane,
Does seem a little weird as the retainer is supposed to mate exactly to your tooth geometry and 'retain' their current alignment.
If you got a new powerchain that suggests that some tooth or teeth are still not in their final position. I would definitely ask your ortho why he/she took your retainer impression while your teeth were still moving.
Regards,
ICE.
Regards,
ICE.
Metal uppers May 2, 2006
Metal lowers September 12, 2006
Finally Nekkid July 11, 2007
With braces - pain is gain...
Some things money can't buy.
Thank God great looking teeth aren't one of them.
“But to see her was to love her, Love but her, and love foreverâ€
Yes, it does make sense, sort of... I bet you are getting a Hawley. He knows what he wants to accomplish with the power chain, so he can have the manufacturer adjust the impression to accomodate that. I was sort of in the same boat when I got the impressions for my bite positioner. I had been using elastics on the left side and it seemed stable enough until the wire was taken out. Then the teeth dropped some. I still had the impressions done and the doctor noted it in his "prescription" for it. I still had to have it adjusted a little more, though, because during the three week waiting period, I continued to use the elastics and got it right on...
Good luck to you.
Good luck to you.
