Hope I won't get into too much trouble....
lillibut
#1 Post by lillibut »
:oops:
I couldn't face the staining anymore, and after some deleberation cut the tubing away from my wire.
The tubing was only to stop the wire from rubbing on the inside of my lip (the ortho assistant persuded the ortho to be nice and put it on. Lovely of her, but wish she hadn't!).
Not gonna touch my braces at all now, I am so much happier and less self concious without the stained tubing. It was horrid! Just hope my ortho doesn't mind.... :oops:
ghostmyimag3
#2 Post by ghostmyimag3 »
lol you gotta do what you gotta do right! It was pretty stained, I don't know of anything you could have done to get it clean.
Metal braces on Uppers and lowers-November 8, 2006
newmetal
#3 Post by newmetal »
Whats tubing? I also have a wire but i dont have tubing, i wouldnt want the tubing, sure it made your mouth bulkier? Mate , if your happy then thats cool.
Newmetal
lillibut
#4 Post by lillibut »
It just made my mouth look unclean!!!
With tubing...
Without tubing....
Ahhhhhh....much more pleasing to the eye!! (not that I'm vain or anything!!)
lillibut
#5 Post by lillibut »
Forgot to say...thanks for understanding and your support x
SDFD TSchott
#6 Post by SDFD TSchott »
I'm going to have to agree it does look much better without the stained tubing!
SDFD TSchott
CODE 4
PS If your in school still you can use the excuse, I wanted a good picture and with the stained tubing it looked horrible.
Adjustment Sept 14th, 2018
Braces off April 02, 2008
Flora2006
#7 Post by Flora2006 »
Yeah it defininely looks better without the tubing thingy.
It's crazy how much staining goes on each month...
cowlypso
#8 Post by cowlypso »
If it was just there for comfort, then it sounds like you shouldn't get in too much trouble. But you might want to call them on Monday just to make sure. Better to check on it early then have them yell at you for messing up a whole month or something. That's just my paranoid perspective.
