Waterpik vs Hydro floss
000Liv000
#1 Post by 000Liv000 »
Last time I was at the dentist, they recommended that I buy a Hydro floss oral irrigator. (They gave me a discount slip so I'll save $30 if I buy one.) The Hydro Floss is $129. here's the link http://oralcaretech.com/Merchant2/merch ... ory_Code=1
Does anyone know if there's much of a difference between a Waterpik and this Hydrofloss? (-Any difference other than price--I believe Waterpik is less expensive.)
:heart:
Orth-ohno!
#2 Post by Orth-ohno! »
I'm not sure if there is much of a difference, but I know I paid less than $60 for the hydro floss, so you might want to shop around a bit! I would also highly recommend a sonic care toothbrush. Between the two them, I've remained plaque/cavity free and now only floss occasionally.
