I was wondering if anyone gets any pain if there sonic toothbrush hits there brackets. I find i have to brush really carefully because if i hit one it makes the tooth feel really sensitive and vibrates my whole mouth
Though im not knocking my sonic i love it makes my mouth feel soo clean
Amy
I had a bit of that trouble a while ago. I just increased the amount of time I alternate sensitive toothpaste and go a bit gentler on the sensitive area. It's really helped.
I have one. I used it for awhile then my teeth started really hurting in front.
I stopped using it and all the pinging pains went away.
I think I'll use it more but only after 10 days or so after a adjustment when my teeth aren't so sensitive.
Just don't push to hard.
