For the past 3 or 4 months now during which time I've had 2 adjustments, I have seen NO movement of my teeth at all. I've had braces now for 11 months. I'm currently using elastics to correct my overbite, which changed alot using elastics for the first month (and only 16 hours per day), and then everything stopped changing! For the past 3 months (and using elastics 22 hours per day), nothing has changed. My overbite is exactly the same. The elastics have put a couple of my teeth in a position to cause lip biting, but won't move any further.
Is there a point where teeth just can't be moved any further. I mean, does everyone have a "maximum" point where their teeth can be moved, and then that's it? If so, I think I would rather just have them off now instead of going through the aggravation if my teeth aren't going to even move despite all the effort.
The main reason for the braces was to correct a severe overbite and several overlapping teeth. The overlapping is now eliminated, along with half of the overbite.
Stalled progress?
Stalled progress?
- jennielee81
Wow, I don't know. Sometimes there are changes that we can't see but they're still happening. I don't know if this is the case with you or not.
Might I suggest pm-ing Dr. Rick? Here's a link that may help you to pm... profile.php?mode=viewprofile&u=5393
I think that may be your best bet. I've not seen anyone on here in the past 2 years ask about this or relate a story similar to yours. Not saying that no one is in this position, just that I've not noticed so I can't help other than directing you to Dr. Rick.
All the Best to you!
Thank you all for the advice and encouragement. I will try to stay patient and look for changes to take place. Also, I did send my question to Dr. Rick to get his advice.
I did ask my ortho at the time of my last appointment, but he's always really busy when I'm there and doesn't have time to talk much. Must go from patient to patient. He basically just told me to keep wearing the elastics.
Ok, I just got a reply from Dr. Rick. That sure was fast!
He said that there is a law of diminishing returns, meaning that as time goes on, the results may in fact slow down. He said I should discuss with my ortho if I should continue or not if I'm happy with how things are now.
Yikes! I'm not sure if I should stop now or not. As I told Dr. Rick, my teeth are far from perfect, but alot closer than when I got started with the braces. I'll probably give it a bit more time though.
movement
my ortho said there would come a time when everything seems to stop progressing cause we can't see it. My bottom teeth have shifted so fast, i'm wondering what else i will soon see after that. My bottom teeth were the most crooked and now they have moved tremendsly!! So, i guess eventually my teeth will stop to where i won't see no progress too.....![Smile :)](./images/smilies/icon_smile.gif)
I concur with Linda !! Patience is needed. Pass me some more of that patience, Linda.I think this has got to be the most testing stage of the braces journey; wearing elastics and correcting bite irregularities. Goodness knows 7 months on and I'm still getting my bite sorted out. It has been extremely slow but I've noticed the feel of my bite has changed compared to the outward look of my teeth. Remember when in elastics you're shifting/moving an entire area compared to the individual teeth movements that you commonly saw during the first few months in braces when in a light flexible wire.!
![wink :wink:](./images/smilies/wink.gif)
![Laughing :lol:](./images/smilies/icon_lol.gif)
Top Braces June 2004
Bottom Braces November 2004
Debanded January 2007
