Are your braces on all of your teeth?
I have them top and bottom but the back two teeth/molars on the top and bottom are not braced in any way.
Is this normal?
I am missing as tooth on the top in the back like the third one from the rear maybe this is why???
Is this normal?
It could be normal, or they may be bracketed later on in treatment.
All my uppers bar one were bracketed from day one and have stayed that way. Most of my lowers were bracketed initially, and the last of the second molars added at my first lower adjustment.
Enjoy the ability to floss normally, I say.
All but one of my teeth are bracketed. On my upper right side, the molar next to the band isn;t bracketed. My ortho said she needed to leave that one off, and she put a bend in the wire at that point (why I don't know). She said eventually she'll bracket it, but she needs to move my teeth over to fill a gap to help fix my midline.
My two top canines are bracketed, but not attached to the archwire. They are severely rotated (90 degrees) and one of them is up really high and dosn't fit into the arch at all. she said they'll be attached to the archwire once my other teeth start to line.
I didn't realize til I got home, that one on either side on the top are not bracketed.....only got ceramics on top the other day...didn't get to ask many questions this time....figured they're gonna do what they do to get the job done...lol
Uppers Braced 1/29/07; 2 Upper bicuspid extractions 9/14/07; Lowers braced 9/25/07
I've got brackets on all teeth (except for my wisdom teeth which will come out when this is all done). Currently (7 weeks into treatment), the wire only goes to the #6 tooth. The last one (#7) on each side won't be attached to the wire until later in treatment - she mentioned when I get to the .019x.025 wire.
JDub
JDub
Braced 12/13/2006
Damon 3's on Top front 6
Damon 3 MXs on the rest
Back Teeth
My back teeth are not banded/bracketed either.
Brace day - uppers bracketed to the first molar
1st. adjustment - added second molar
2nd. adjustment - lowers bicuspid to bicuspid
next adj - will get the last four lowers
It has been a nice way to ease into it, but that wasn't the reason it was done that way. Each case and each ortho is different, but they all get the job done.
