Okay guys,I know this sounds like a broken record but I have another loose bracket. It is now 9 loose brackets to date and they were all on either gold or ceramic crowns. It is the same ole #5 upper right side that came loose, its a gold crown and last time I had an ajustment on 1/19/07 they put on a new bracket then and it now its loose for a second time since then. I stopped in at the ortho's after work today to tell them and they called my house later to say I needed to get spacers in two weeks on Friday and then on the following Monday I am to get a band put on and new wires put too, all in the spirit of healty teeth. And I was was just starting to feel smug in my braces journey. Its a downer I know but at least I can get NEW colors EH!
Thanks for the cheering up Denise! I had spacers put in a while back for another bracket turned bad. It wasn't that bad, it looked like a pair scissors on each side of the tooth. And I know this sounds funny but the tooth with the loose bracket is really sore. I fiqure thats because its not supported by the archwire anymore.
I know what you're experiencing. Seems like all is going fine and someway, somehow a bracket comes loose. It does make the naked tooth uncomfortable yelling wrap me in metal, where's my elastic.... I love that color lig, please don't leave me without a wire support!
Seriously what seems strange is I've had several loose brackets. All on the same two teeth.
Mike
But who's counting?
Jaw Surgery June 1, 2009
Hi TI, it sure is annoying. I think I have had a total of maybe 10 or 11 come off and also a molar band. My ortho finally put bands on the ones with the metal and it has been WONDERFUL not having to worry about them popping off all the time. But, I am kind of jealous because you get to have colors, I have Damons and don't have ligs. Lee
iBorg and ladylee, Thanks for the kind words, it really does help.
Mike-This is the 3rd time loose on this tooth and the other tooth that did come loose 3 times as well got a band too. This one is ceramic and the other was a gold crown.Go fiqure.
BTW-Lee I have Damon's on botton and the Ortho said I can have colors as long as he sees sufficient movement in them. I sort of had to beg politely to get them .
Not to poke fun of you Tony Stewart fans , but I had a friendly bet with a gal at work that I would have Orange ligs if he would have won and she would have had to wear A Dale JR. shirt if he had won. Good thing Daytona is only once a year.
