traditional and lingual at the same time?!
prettybetty3
#1 Post by prettybetty3 »
Just being imaginative...
I know this probaly is not feasible...
Have you even wondered having lingual and traditonal braces at the same time! Would that double (not only the pain) but the treatment time? :lol:
If that was the case, I wouldn't mind the pain and the mouth full of metal!
Lisa65
#2 Post by Lisa65 »
Do you mean both on the same teeth?
I'm not sure if that is feasible, but I believe lionfish has top linguals and bottom traditional braces.
lionfish
#3 Post by lionfish »
I do indeed, lisa65.
Absolutely no problem mixing and matching, however I only have brackets on one surface of each arch. There will be no difference to treatment time and I've not had much pain either.
jenfire
#4 Post by jenfire »
I would think that brackets/archwires on both sides of the teeth would inhibit movement to a great extent, not speed things up.
Ceramic Braces and RPE, estimated treatment 18 months
