Damon 3 Ice
nickym
Damon 3 Ice
#1 Post by nickym »
Hi, does anyone else have or know anything about Damon Ice brackets? I've got them on my top six teeth. I'm worried because mine are looking less white after only a week. They look fine at the moment because they're the same colour as my teeth but if they get darker will the ortho change them? I don't have ligatures because they're damon braces, it's the little clips that are staining so maybe they can be replaced or cleaned during my next ortho visit?
Epyx
#2 Post by Epyx »
Nicky, to the best of my knowledge, the brackets you are referring to are just called "Damon 3":
http://www.ormco.com/index/damon-thesys ... bracket-01
I have them on my top row, but I haven't noticed any staining in 8 months of wear.
The name "Ice" is used on another Ormco product line called "Inspire Ice", which is a traditional ceramic bracket:
http://www.iceclearbraces.com/
