Been a while since ive been on here but though this is the best place for good quality advice!!! well here goes...
I had my barces put on on 05th of December and they are already straight, i have quite a few gaps because I had 4 extractions, so I'm geussing that after my second adjustment these will close (correct me if im wrong), but I am wondering if I am moving pretty quick or this is normal??? Im hoping to only have them on for 18 months, what do you think????
I agree with KK. And closing 4 extraction gaps should take some time. 18 months sounds pretty quick. Remember after the teeth are straight next comes the alignment top and bottom and adjusting the bite. Relax.
Top Braces June 2004
Bottom Braces November 2004
Debanded January 2007
Yeah I agree, but my gaps are pretty much closed, its just that they have all spread, it just seems all pretty quick, I was just wondering if anyone else has been in the same situation.... I will speak to my ortho when I go, just was curious. I am very relaxed thank you!
