Gaps on the move!
loulou123
Gaps on the move!
#1 Post by loulou123 »
Was just wondering if anyone else had, had this happen to them:
few months ago i noticed that a gap was appearing between my two lower front teeth, it grew bigger an d bigger, my ortho seemed quite surprised by its appearence and fitted a powerchain to the lower 4 teeth to pull tem back in. The gap has now closed up but has moved to the tooth at the end of the powerchain.
Know this is only a little thing but i have visions of the ortho chasing the gap all around my lower jaw, as i can imagine next time she will add an extra link to the powerchain and the gap will move on again! :roll:
Just wondered if anyone had any similar storys to set my mind at rest. :D
DaisyMay66
#2 Post by DaisyMay66 »
Very common occurence. No need to worry, the space will close. Your teeth are just following the natural laws of physics.
samantha_lou
#3 Post by samantha_lou »
My upper two centals started developing a gap, so ortho put on a four link chain across the front four, so from lateral-central-central-lateral and now the gap has moved between my laterals and canines! I'm pretty sure I'll be getting a six link chain next time, and then the gap will be on the move again!
Pirate Wench
#4 Post by Pirate Wench »
I had a gap developing on my top arch too, but (like Samantha_lou) I got a 4 link powerchain. The space moved to the end of my powerchain. That was before Christmas.....I still only have a 4 link chain. The ortho said the space is easily corrected and there are other things that take priority over it so it will be dealt with at a later date!
No worries....it is quite normal. My ortho was not surprised at all that I developed a gap. As a matter of fact, as soon as he changed to the wire to the higher gadge he said it would probably happen :) .
