Facial structure changing?? Arch wire loops??
Hi everyone,
I haven't posted for awhile so I figured I would give a quickie update. Well today I had my most interesting adjustment yet. I got a powerchain put on my top four front teeth and a couple of "kinks" put in my top arch wire to get my teeth even. (A couple teeth were sitting a little bit higher than the others). The powerchain is making me a little bit achy but I should be fine in a few days.
Anyways, my questions is has anyone noticed a difference in their facial structure since getting braces? I have had an expander in for the last 6 months and I'm noticing that my cheekbones are more defined. When I look at pictures of myself pre-braces I think I look significantly different! I love my new cheekbones!! I'm thinking that the expander might be responsible for the change in my face?? Also, today at my appointment, the orthodontist made a loop on my top arch wire on both sides... Does anyone know what this is for?? I completely forgot to ask!! I have a feeling he is getting me ready for elastics?? Any thoughts?
WeezieGirl25
WeezieGirl25
I have found a similar change Weezie,
before I had a very flat type mid-face section and now I find that have some form of cheekbones... I'm not taking supermodel amazing, but they're better than before.
I find that my face has become wider and my top lip has become a tad more defined than it was before.
I had to wear an expander for 5 months, and then this other kind of like expander-holder-place thing (as you can see I have much knowledge on orthodontics lol) for another 3 months.
As well as having to wear reverse head gear for 5 months (thankfully only at night)
It's known that an arch expander can certainly change your face shape. Are you guys under 21 i.e. still growing? I am late 20s and pretty happy with my appearance, so I was concerned of a change in face shape, but my ortho reckons the expansion will be so small "a few mm" that it won't make any difference... Also, did you guys have a significant amount of expansion?
I'm 27 and my face has changed quite a bit after getting braced. Well, it was slightly asymmetrical before, due to a molar extraction a few years ago but I think it was only visible to me.
My upper teeth have seriously shifted to the right (which is bad but temporary), and I guess the move restored the bone that was missing from the extracted molar. I can feel the bone where there was a hollow spot, and I can also see it: I used to have a naso-labial fold - wrinkle! - on the right side from smiling. This wrinkle has smoothed out almost completely. So while my entire face looks more asymmetrical because of shifted midlines, when I keep my mouth closed and you don't see the midline, it looks more even than before.
They say symmetrical faces are more attractive, so I'm hoping for the best
But braces definitely change your face!
