I had my expander "installed" yesterday... and all I can say is OUCH!! It doesn't hurt now... but it hurt like crazy when they were putting it in...
My question is... Is there any "around-the-house" product that I can use to clean my expander? Or do I need to buy a special "tool" to do this. I ate won ton soup for lunch today, and did very well eating it... but the chewed up wont tons kept getting stuck on top of my expander... I'm sure that I will get used to it, but it was very annoying. I ended up using my travel sprial brush to get all the food out of there...
I was just wondering if there was an easier way to do this...
Thanks!!!
Amanda!
Expander cleaning?
You might want to invest in a Waterpik. They are invaluable for cleaning gunk out from between brackets and under expanders. If you can't get one or don't want to, then something like a syringe is great for squirting water under the expander to dislodge bits of food.
I haven't got an expander but I've got a Nance/TPA and a lot of extra wires and springs, and it all attracts food like nobody's business. I find that having a glass of water with meals helps disperse some of that clogged up feeling. Straight after eating I head to the bathroom to swish and rinse with water.
hope the expander does its thing and you soon get used to it.
Lisa
Lisa
Yes, a Water Pik would be a great investment!!! I have had my expander for almost 3 months, don't know how I would of cleaned it properly without one. And a side note... I have noticed once you start expanding the food doesn't get stuck up there as much and comes out easier because there is a bigger gap in the expander. haha ![Laughing :lol:](./images/smilies/icon_lol.gif)
![Image](http://tickers.TickerFactory.com/ezt/d/4;35;87/st/20070326/e/getting+my+upper+braces/k/a6ad/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;13;6/st/20070817/e/getting+my+lower+braces/k/e225/event.png)
Upper Expander in for 5 months, 6 days. January 07- June 07
