Wisdom teeth removal and facial changes
brandee987
#1 Post by brandee987 »
My dentist is suggesting I have my wisdom teeth removed as there is minor decay on them. I have HUGE wisdom teeth on the bottom and they are further out to the sides of my cheeks than my other teeth. Anyway for anyone who has had wisdom teeth removed did you notice any facial shape changes?? TIA!!!
Ceramic Upper braces: November 29, 2005
Metal Lowers go on: March 7th, 2006
lionfish
#2 Post by lionfish »
I've only had one pulled (lower) and haven't noticed any facial change.
Naduah82
#3 Post by Naduah82 »
I had 2 bottom wisdom teeth extraced and didn't notice any facial changes. They weren't all the way up though, they were impacted.
becks
#4 Post by becks »
Same here. All four were taken out and no facial changes.
Braced ~ March 13, 2007
brandee987
#5 Post by brandee987 »
Thanks for the input guys! I already have too thin face and I dont want anything making it look any thinner!
nickym
#6 Post by nickym »
My dentist has suggested I should have my wisdom teeth removed as they are not all the way through and this causes the gum to get infected and swollen occasionally. I really don't want to have them out unless I have to. There's only about a couple of mm left to come through, does anyone know if it is possible that braces can help bring them through?
