Can braces fix rotated teeth?
When I was younger, I had 2 bottom molars pulled (one of each side). through the years my teeth has drifted. My premolars on each side are "twisted." Can braces fixed these rotated teeth?
thanks
Dugsmom
thanks
Dugsmom
I am sure they can, I have seen cases on this website of very twisted teeth that have finally ended up looking perfect. I myself had a tooth that was a twisted and that got fixed up, now I cant even tell if it was twisted to begin with until i see the before pics.
The future depends on what we do in the present.
Yes, it most likely can! It is amazing what orthodontics can do! I'm not sure what the nature of your tooth rotation is, but I'm sure if you look through some of the postings here you'll find someone with similar issues and can see how orthodontics fixed it.
Ceramic Braces and RPE, estimated treatment 18 months
In my experience, yes. The way they do it can sometimes seem a bit odd but it can be done.
My front bottom teeth were so crossed over that you could take the left one out and there'd be virtually no gap! It was almost at a 90 degree angle.
But they've spaced it out and the tooth is now being pulled back into place and will be straight
HTH
HTH
Sounds like the twisting is from a malocclusion and lack of posterior support. How many molars are you missing? If you do not have sufficient molar support you may be right back where you started many years down the road. I assume your ortho and dentist are in proper communication about their respective treatments?
Best,
Rory
Best,
Rory
Not in all cases. Think about the size and shape of all teeth including the root size and the number of roots. Anterior teeth are for tearing and ripping, back teeth for crushing and lots of force. Premolars are hybrid. So if you lose molars the brunt of your occlusion moves forward to smaller crowns and roots. The adaptive nature of the body will shift teeth to minimize trauma to an isolated spot and make it more diffuse. Occlusal trauma will do crazy things and move teeth in different ways. Don't take what I said about missing a molar as truth in all situation. But in the OP's case, I am comfortable in guessing that is the case.Wow. SO let me see if I have this atright (no pun intentded): without molars to provide posterior support, premolars and/or teeth further forward can rotate? I imagined that they would only rotate if overcrowded.
Hope that helps.
Best,
Rory
Thank you all very very very much for answering my post. It was comforting to know that my rotated teeth can be fixed. I saw an ortho but he didn't mention those teeth...I should've asked him but he took off before I was able to ask questions. He left me with his assistant who had already told me a few things that I knew were not right so I didn't want to waste my time asking her.
Thanks again
Dugsmom
Thanks again
Dugsmom
Re:
lionfish wrote:
> Yep, I've had a premolar that was rotated 90 degrees, pulled into line with
> braces and powerchain.
how long did it take? I just stumbled onto this thread because I have the same thing (my very front tooth is rotated 90° since I was in 2nd grade lol) I want to get my teeth fixed so bad but my parents never did anything about it.
Re: Can braces fix rotated teeth?
Nobody could say how long it might take for you. An orthodontist would have to look at your teeth and tell you. Each case is different.
