how many teeth do you have left?
while I was reading the post, realized that due to mature age of many of our members including myself, some of us have less teeth than we should. I was reading this lady's post and saw how few teeth she had and I counted mine. I have total of 23 teeth. I'm missing a top left molar.
I think this might have effect on my progress because top leftside has less anchor teeth to properly do that job? so my midline is way off.
Any of you are missing teeth like myself?
mother of one.
I am 31 and I have 26 and half teeth. One bottom second molar was pulled away, because it was quite rotten. The upper molar has a huge fiulling. It did not need root canal yet. The filling will not last forever, maybe 5 years, after which I need a root canal and a crown. But if I will go and have a crown, I have to get a implant on the bottom, otherwise it does not really make sense.
I have 24 teeth, for now. I had 4 premolars removed before braces and my wisdom teeth haven't come yet. I hope that when they do, they can stay. I see no reason to remove them if there's no impact problems. I have a fair few fillings already as well, so I guess that's in a way less "tooth".
Sim
Sim
Damon 3 braces for 22.5 months.
30th August 2005 - 13th July 2007
I seem to be in the lead so far with 30 teeth
I'm 28 and had 2 x upper second bisucpids extracted last year to help with overjet (the teeth I was very sad to lose; the overjet not so much
Otherwise I am still the proud owner of 4 x healthy wisdom teeth (all of which fit with nearly no crowding which impressed my dentist & my ortho says is very unusual).
Unfortunately my ortho has started talking about possibly extracting at least 2 x wisdom teeth further down the track but I'm not letting them go without a fight!
(Yes, I did ask him why, and I have absolute confidence that he did answer my question. Unfortunately, I didn't really understand the ortho-talk response. Not to worry, we'll be discussing it in far more depth if and when the time comes
I am 34 years old and have 27 teeth. All four wisdom teeth were removed in my early 20's and I lost one tooth due to decay (an upper 2nd premolar) in my late teens early 20's. I had a root canal and cap put onto a 3rd premolar in my early 20's as well. My two front teeth are only partially "real". I broke them off when I was about 10 or so. I fell on my face roller skating and had to have them bonded. I've also got fillings on several other teeth...most minor, two are pretty good sized fillings. So taking all that into consideration, I guess I have about.....24 teeth.
Braced ~ March 13, 2007
will this work?
When you win, nothing hurts....Joe Namath
