Extractions caused too much space.....
Irinadax
#1 Post by Irinadax »
I have had two upper bi-cuspids extracted to relieve crowding. But it appears that now the extractions caused more space than was needed. In moving my canines back to fill the extraction gap, a new, and rather noticeable gap has formed between my canine and the teeth next to them. My ortho's solution to this is to push my four front teeth BACK. I DO NOT want to do this b/c I'm so afraid it will flatten out my profile (I have thin lips to begin with). My question is, why can't he just move the canines and molars FOWARD? How important is it that the canines FIT in the right 'bite position' if it's just a matter of millimeters? Has this happened to anyone here?
spaced*out
#2 Post by spaced*out »
I had four teeth extracted and they are pulling my teeth back on top and forward on bottom to keep my teeth from shifting on bottom they put me in a LHA Its a little bar that fits behind me teeth and keeps them from filling in the extraction hole. I do wish you the best of luck
iBorg
#3 Post by iBorg »
I have the same problem from 25 years ago. My ortho's plan is to move the teeth forward and then spread them out a little. after braces, they will be veneered to add length to them. This should repair some of the damage from grinding. The hole is not big enough for an implant so I'll have a bridge to fill the holes.
I truly understand your concern. My teeth were lost prior to this round of braces from where they were pulled back so far in my mouth.
Best of luck to you.
Mike
But who's counting?
Jaw Surgery June 1, 2009
payoki
same here.
#4 Post by payoki »
because of my overbite, I did not object to upper biscup extraction but I felt that I didn't need any extraction fr lower teeth but my ortho removed four of my biscups Now my ortho is trying to move my lower back molars forward to fill in the extra space. My chin is looking smaller and smaller.. :cry:
mother of one.
Irinadax
#5 Post by Irinadax »
Thanks for the encouragement folks :-) I know I have a valid concern and I think my ortho sometimes forgets I'm 35 and not 12.
