Enamel reduction/slimming down of the teeth?????????
What exactly is that anyways? What do they do? What is it for?
Brace Free February 17th, 2009
Braces January 29, 2007
They shave about half a mm of enamal off a few teeth to narrow them and create small(ish) gaps between each teeth in order to move the teeth back/straighten them. Should create the same results as having teeth out but avoids taking out healthy teeth and the possibility of creating too much of a gap and getting the 'sunken' look.
I suppose it all just depends on your teeth, treatment needed, and whether your ortho is trained to do it or not.
Hope this helps
Hope this helps
I had this procedure carried out on my lower incisors. Totally painless, although admittedly, not entirely pleasant. In my case, the ortho used a few different files, starting with a coarser grain, before smoothing them with a finer one, just like you would with wood really. I wouldn't worry about it though, it's preferable to extractions!!
That does not sound like fun!! Although anything would be better than extractions, they are scary!!FlyingScotsman wrote:I had this procedure carried out on my lower incisors. Totally painless, although admittedly, not entirely pleasant. In my case, the ortho used a few different files, starting with a coarser grain, before smoothing them with a finer one, just like you would with wood really. I wouldn't worry about it though, it's preferable to extractions!!
