Weird spring
Weird spring
I tried to search to find out what this is and have had no luck.. I checked the links for the newbies.. I tried googling and I'm having no luck. I'm curious to see if anyone can figure out what this is. I've got an expander on the roof of my mouth. Found TONS of info about that. I've got bare brackets on my front tops and bottoms... On my bottom teeth I have a spring that is attached with two brackets.. it also has a wire that is broken in half that goes behind my teeth.. (spring and wire) Does anyone know what the heck that is? And what is it for? I even read some of the orthodontic journals trying to find this thing and I can't figure it out. I'm not sure if this just has to do with when I get my wires on or what. The little wire is pinching/scratching my tongue and I would love to know what it's purpose is.
THANKS!!
M
THANKS!!
M
I'm going to do that when I go back in. I was shocked that I got all this at once I thought it was only going to be the expander.. anyone who's had one knows there isn't much talking going on right after that sucker is put in. haha I've got it on my list of things to ask but man it's driving me crazy.
I'm at work so I don't have a camera.. but it's a long spring it spans. I think they're on the bottom 1st bicuspids? and then there are springs from there back to the first molar where the brackets are. so it's all the way across those teeth. I'd give anything for a camera right now so someone could tell me what this thing is. I'm wondering if it's like another expander? but for the bottom? is that possible?
Sometimes people have expanders on the bottom. Does it look anything like this?
http://www.braces4oxford.co.uk/Expanders.htm
A couple of members here had lower expanders, Gennel and bracieb are the ones I can think of. There is a thread here about it. viewtopic.php?p=191936&sid=3472122164b0 ... 605563ae34
If you can manage to get a pic, somebody here might be able to help, or at least guess
LISA You're a genius!!! That's it!!! Except I actually have some springs that are going on the sides too. When I looked at it better to figure out what teeth it was hooked too I realized it really looked like another expander. I can't wait to go back and find out what on earth we're doing in my mouth! lol
