Time between adjustments
i cant wait for my first adjustment it on the 222nd but is it every 6 weeks or 6 weeks then 4?
From what I've seen, I think most people get adjustments about once a month or so. I've gotten adjustments about every 4 or 5 weeks. But so far the only factor in length of time in between has been when my ortho is available in combination with when my schedule is available to go see him! But agreed that it depends a lot on what treatment stage you're in, etc.
I was going every three weeks for quite awhile, which was really pretty hard, but was mostly to retie the elastic on my impacted canine. Thankfully, the office was really close to where I was living at the time. I would be *so* happy to be able to go in once every two months! I don't think I've ever gone longer than five weeks or so, but usually all that happened is I got new ligatures and the canine tightened.
with my first adjustment it was supposed to be 8 weeks but I ended up going 7 due to me leaving on a trip with work. then the next adjustment was supposed to be 6 weeks but it ended up being 7 again due to me being on a caribbean cruise. lol My 3rd adjustment is set for 6 weeks. I was told adjustment will be determined at each adjustment. Good thing my ortho is close to work as I usually just leave work and have it done.
Brace date: 5/2/2007
Debanding date: 1/14/2009
Ceramic Braces: 20 months
Hi! My schedule is supposed to be every 4 weeks but my ortho has a busy clinic so for the next adjustment, my schedule is pushed to 5/6 weeks apart. But its ok because mostly what he do every adjustment changing the ligatures. i'm getting a bit frustrated though because my teeth are spacing apart and in between my teeth there are ugly brown stains that I can't remove even though I use whitening toothpaste because I simply can't reach them! I wonder whether a regular cleaning can remove these stubborn stains?
19th May 2007- Two right premolars extracted
26th May 2007- Two left premolars extracted and spacers in
2nd June 2007- Upper arch braced
5th July 2007- Lower arch braced
I have all metal conventional brackets
Looking forward to straight teeth and nice smile
