Hi all,
I have been out of braces for a couple years now. Just this week I had all of my wisdom teeth extracted, and I'm a little concerned about my teeth shifting and ruining all the hard work I went through previously!
I'm considering going back to my orthodontist to see if they can adjust my hawley retainers (I still have them, though I admit I haven't worn them frequently) or if I can get a new set of retainers made. Has anyone else done this? How much do I really need to worry about my teeth shifting?
Thanks!
Jet
Post-braces; teeth shifting after wisdom tooth extraction?
Not to freak you out, but after having all 4 of my wisdom teeth taken out my teeth (lowers more so) shifted pretty badly. Maybe if I had worn my retainers after the procedure it wouldn't have been as bad?
Upper ceramic and lower metal braces
Round #2 - Had braces as a teen for 4 years!
Treatment time: 14 months
Braces on: July 19th, 2006
Bottom braces off: August 29th, 2007
Top braces off: September 19th, 2007
BLWR on bottom and Essix on top!
- jennielee81
Ocean, I'm assuming that this was in a "previous" braces treatment?
I was thinking while I was reading this that you still had your upper braces on this time. So it must have been when you were a kid.
Do you think it was from the molars being removed or from the retainer wear? Or do you think it was from both....
If your wisdoms were errupted and a presence in your arches, once they are gone there is room and yes things will shift, slowly over time. A small shift will set you chewing differently which in turn etc...Frankly you have answered your own question, so see your orthodontist for :
1) are these retainers still working for me?
2) should i get new molds made as soon as the swelling goes down etc?
3) how often should I wear them for adequate retention?
Thanks guys!
I got out my retainer and while the bottom still fits great, the top is a bit snug and almost doesn't quite fit. I've already noticed a lot of shift on the top; trying to floss between my front teeth there was no resistance (normally these teeth are a little snug). I'm going to wear these overnight and see if they will settle back in.
Either way, I think I'll make an appointment with my Ortho to see what he recommends.
Thanks!
Thanks!
- jennielee81
I really think it has way more to do with not wearing retainers than having your wisdom teeth removed.
My son stopped wearing his retainers after 2 years and his teeth have moved a lot since then and his retainers don't fit at all.
I agree with Meryaten, wear them a few nights a week and they'll probably stay put better.....regardless of the 4th molar removal.
