first adjustment
first adjustment
tried a search nothing good from you guys experience was there a real change and do some of you guys get power chains on the 1st adj.?
The adjustment appts. varies with everyone. Alot of it depends on how fast/slow your teeth have moved and this can depend on how many weeks it has been since your braces were placed. I always look forward to my ortho. appts. to see what will be done - sometimes not much and sometimes alot. My ortho sometimes tells me what will be done at my next appt. if he plans to change the wires, etc., which usually means a little longer for the appt. Most of the time, he takes a look at how my teeth and bite are looking and decides what to do from there - I think he always has an idea of what will be done at the next appt., but it all depends if my teeth have moved to the place he was expecting.
Good luck.
ssfw
Good luck.
ssfw
Braces removed: 8/19/08
Next appt.: 11/18/08
Not everyone gets a wire "upgrade" at the first adjustment.My first adjustments coming soon too and I had the same question. People are warning me that the thicker wire is going to go in and make the teeth tender again any truth?
I got a part powerchain around adjustment no. 3, I think. It was used to rotate a lower premolar and only stretched across 3 teeth.
My tops didn't get a new wire at my first adjustment (but I did get lower braces then), but both arches have had wire changes at every adjustment since. I didn't get a powerchain (on top only) until my third adjustment.
I think it really depends on the person what happens at the first adjustment, though. Everyone's teeth are different, so your experience will probably be unique to mine.
*The Sallymonster*
Now in elastics, too! Since 2/25/09.
I had my first adjustment today. All he did was take of the the old purple ligs and put on new pink ones. When I first got my braces on he wasn't able to but the ligs fully on each tooth, but now all of them have a nice pink lig wrapped around the bracket.
It wasn't very eventful. I kind of wanted a new wire, or powerchain. I want these braces off. fast.
