decay under brackets.
I have heard of people having their teeth rot or have cavities because of the bonding not sealing between the bracket and your tooth. I am kind of scared of this. Has anyone hear of this? And is it preventable with really good teeth brushing, using mouth wash and stuff. I know sometimes when I eat and cant brush right after I try to swish water around and don’t drink a lot of pop and juice. So I am hoping that helps. Lol I wish I would quit hearing stories. Being a newbie makes you panic..lol.
I was really afraid of that, too, when I started. I haven't had any trouble with my teeth, though. Decay can occur more easily with braces, but since you are probably brushing way more than normal, you should be fine. For my own peace of mind, I decided that I would go to the dentist for a check-up/cleaning once every 3 months. It is pricier, but it's worth it to feel that my teeth are safe. This year, I think I adjusted to once every 4 months. Regardless, if you pay attention, you should be fine I think.
four bicuspids removed 1/3/06
- jennielee81
!!!!THIS IS NOT COMMON!!!
That said,
I started a thread about my 13 year old daughter who got cavities from a bad bonding job. She's got at least 2 possibly 3 cavities on incisors and will have to have those filled in the next week. Please read on and heed warnings given above and here about hygiene!
THIS IS NOT COMMON!!!!! If you go here, viewtopic.php?t=22081&start=0 you will see her bad bonding job. The ortho is partly to blame and my daughter is partly to blame and I am partly to blame....
Had I taken her in more often for dental cleanings and checks, this wouldn't have advanced to cavity. If the ortho had done a better job with bonding, there wouldn't have been plaque traps and if she'd been better at brushing..well, you get the picture....
short story: make sure your ortho has cleaned up all excess bonding material and BRUSH well, and see your dentoist at leat every 6 months.
That said,
