powerchains
braces138
powerchains
#1 Post by braces138 »
I just got powerchains.My front two upper teeth moved so much it caused a gap.Two days later,the teeth are closer together.Amazing.
braces138
#2 Post by braces138 »
NOW THAT MY GAP CLOSED IN TWO DAYS WITH POWER CHAINS,WHY DO I have to wait 7 weeks to go back? will they remove power chains then? i really like using a colored power chain since i have self ligating brackets and cant use the colored o rings?
MikeCordell
#3 Post by MikeCordell »
You could try to convinve your orthodontist to see you more often. I persuade my orthodontist to schedule my visits as close together as possible. I've had two of the strongest powerchains stacked on top of each other across my lower teeth to get the gap closed. Military orthodontists sure can be creative.
ilovemacs
#4 Post by ilovemacs »
You have to wait 7 weeks so that the teeth can "learn" their new poitions, if that powerchain was removed all progress would be lost, and the gap would open back up. :D
