how often is your adjustmemt visit?
adultbraces
#1 Post by adultbraces »
My ortho who's registered as an ASO and lectures in UCLA and so sorf.. She's very busy and alot of patents wants to see me every 4 - 7 weeks once my brackets and wires are done. That seems like awfully long time.
What is actually going on between visits?
Is there any adjustment do you do yourself at home b/t visits?
How often do you go see your ortho?
* treating for minimal overbite /overjet and minor crowdness
4 premolar extraction
smart clip metal braces
treatment 20-24 month*
nogota
#2 Post by nogota »
My visits are every six weeks, which I believe is the average. Moving teeth is a slow process, and so they are slowly shifting between visits. You shouldn't have to do anything in between visits, unless specifically instructed to by your ortho.
MikeCordell
#3 Post by MikeCordell »
I try to go on the short side of every four weeks. Preferrably less.
Lisa65
#4 Post by Lisa65 »
Generally my ortho tells me to make appointments for 6-week intervals, Once in a while he's had me come in sooner if there's something he needs to do. Some of his patients come less frequently. When I was in reception last week I heard him tell somebody to make an appointment for 10 weeks.
The wires are constantly working to move the teeth so plenty will be happening in between adjustments without you needing to do anything at home to help the process.
bracesafter40
Re: how often is your adjustmemt visit?
#5 Post by bracesafter40 »
adultbraces wrote:My ortho who's registered as an ASO and lectures in UCLA and so sorf.. She's very busy and alot of patents wants to see me every 4 - 7 weeks once my brackets and wires are done. That seems like awfully long time.
usually every 4-6 weeks as they are at my office every other week, hence the variation; i've had visits twice in a month such as this past Oct. next visit is jan. 8 or 11 which is 6 weeks away from the last one.
i dont do any adjustments between visits myself.
http://bracesafter40.blogspot.com
Bridge Sectioned: Feb. 14, 2007
Last Pre-braces cleaning: Feb. 20, 2007
#21 Extraction: Feb. 20, 2007
Sentenced: 32 months
Top Braced: Feb 28, 2007
Bottom Braced: Apr. 4, 2007
New Ortho on Apr. 25, 2008
May 6; fluorescent blue ligs incl. upper powerchains. 2 elastics; Sept. 2, 2008.
Next Adj.: July 7, 2009 at 8:30a
platinum
#6 Post by platinum »
In the beginning every 6-8 weeks, but now I have visits every 4 weeks.
adultbraces
#7 Post by adultbraces »
Lisa65 wrote:Generally my ortho tells me to make appointments for 6-week intervals, Once in a while he's had me come in sooner if there's something he needs to do. Some of his patients come less frequently. When I was in reception last week I heard him tell somebody to make an appointment for 10 weeks.
Wires work by it self?
I'd think adjustment are done at the visit for rest of another 4 weeks, that's gotta be hurt.. Does the pain wear out?
Lisa65
#8 Post by Lisa65 »
Yes, the wires work by themselves. They are made of a special alloy and are popularly known as "memory wires". When the wire is bent out of shape to go through your brackets, it "wants" to go back to its original shape. The resulting force works constantly to move the teeth. The days of painful monthly tightenings are long gone. The wires used today exert constant light forces on the teeth.
You might find it helpful to read through the "braces for newbies" section here. viewtopic.php?t=11430
BobKitten
#9 Post by BobKitten »
i asked my ortho about this when i first started going as i wanted it to happen as quickly as possible... said that the movement seemed to happen within a week or two, why can't i just keep coming in?!
she explained about the movement of the teeth - how the roots shift and squash one side and have to be built up again on the other etc, and, apparently 6 weeks is an average, but 4 is a minimum - i've had mine done fairly regularly at 5 week intervals (which is handy if i've had to postpone appts due to illness, i feel as if i've not got 'wasted' weeks!)
mariahfromchicago
mariah
#10 Post by mariahfromchicago »
I go every 4 weeks. But since I might be moving and left my orthodontist because he was so mean (long story) I haven't gone in 5 weeks! It's good and bad.
- mariah :banana:
Miss Smiley
#11 Post by Miss Smiley »
I go every 3-4 weeks as they tell me to schedule. My friend is going every 6 weeks. I have clear braces and she has the traditional stainless steel ones with rubber ligs. My ligs are changed out in the office at every visit and my wire sizes have remained the same for most of my treatment. As of two months ago, my ortho started working on correcting my midline and closing the remaining spaces from my premolar extractions (which are almost closed.) My friend did not have any extractions except for her wisdom teeth which created crowding after her first round of ortho.
Est. term: 30-36 months
mihaelici
#12 Post by mihaelici »
I used to go for adjustments every 3 weeks, now I think I'm gonna go every 10 days, as my ortho told me she wanted to try to rush the movement for the left canine, which is pretty badly positioned. :?
ibraceface
#13 Post by ibraceface »
Currently I go every 3 weeks because my ortho is trying to being my impacted canine down. Yay! :) After that- not sure how often i'll be seen- hopefully less frequent!
Rach
#14 Post by Rach »
Hi
My ortho puts down 6-8 weeks and when i book it at the reception, most of the time i get 6. Ive only had it at 7 if hes at a meeting or away or something at the 6th week. Of course you do get exeptions when you need to go a week apart for something, like impressions.
Rach xx
Feel free to take a look at my SurgeryBlog
Chris1960
#15 Post by Chris1960 »
My ortho said 6 weeks but I got the first one scheduled at 5 because of the Christmas holiday. If they try to schedule me for 6 weeks again I'll say I'm busy that week and try to get in at 5. I plan on doing this for the whole treatment. At least until they catch on. I should be able to shave a couple of months off the treatment with this plan, right? :wink:
