How Many Teeth?
Spanner
How Many Teeth?
#1 Post by Spanner »
This may sound like a daft question but how many of your own teeth do you have left?
I've only got 23 left. We should have 32 inclusive of 4 wisdom teeth but I surely can't remember having 9 removed :shock:
browneyedgrl
#2 Post by browneyedgrl »
I have 28 left, I had my wisdom teeth removed about 20 years ago.
lilblackdress
#3 Post by lilblackdress »
I have a full complement - 32
mihaelici
#4 Post by mihaelici »
I have 30 now - 2 lower molars will be removed sometime next year and maybe 2 wisdom teeth will come down as well (I'm not sure yet).. :GapToothed:
Lisa65
#5 Post by Lisa65 »
I have 24, 12 in each arch. I had 4 premolars pulled when i was 12 and 4 impacted wisdom teeth out when i was 21.
ilovemacs
#6 Post by ilovemacs »
I have 32-- my 3rd molars are starting to come in now. :shock:
Betty Bat
#7 Post by Betty Bat »
I asked this question a while ago. If you search, you might find some more replies.
P.S. I have 27 right now. 1 wisdom tooth pulled. 2 wisdom teeth didn't come in. 2 teeth were baby teeth only and had no permanent teeth behind them.
P.P.S. Having fewer teeth than "normal" is called hypodentism.
muppet
#8 Post by muppet »
Hi,
I also have 24 teeth. Four wisdom pulled out 8 years ago, two top 4's and two bottom 5's pulled 7 weeks ago. If you count the 3 crowned and one that has been built up after breaking in half that makes 20 whole teeth 3 stumps and a half :lol:
Before the 3 stumps were crowned I knocked them out (hence the crowns) I sat next to my teeth in A+E for 20 minutes (they were having a little bath in a pot of saline) then the doc came along and put them back in my mouth :o And there they stayed untill they discoloured to silver blue and were crowned.
AliKat
#9 Post by AliKat »
I have 26 all in! :HugeGrin: 14 on top including 2 wisdom and 12 bottom including 2 wisdom, 4 were pulled when i was really young from bottom set, 1 was pulled from roof of my mouth and other one never came through!
AliKat
#10 Post by AliKat »
I have 26 all in! :GapToothed:
14 on top including 2 wisdom, one pulled on the roof of my mouth, th other didnt show up!
12 on bottom including 2 wisdom - 4 pulled when I was really young
AliKat
#11 Post by AliKat »
14 on top including 2 wisdom, one removed on the roof of my mouth, th other didnt show up!
12 on bottom including 2 wisdom - 4 removed when I was really young
AliKat
#12 Post by AliKat »
Sorry about the multiple posts it was giving me an error "DeBUG MODE" Didnt think it had saved!
ibraceface
#13 Post by ibraceface »
24...
I had 4 premolars and 4 wisdom teeth extracted. wow! :)
Spanner
#14 Post by Spanner »
Thanks everyone, I don't feel so bad now even though I have the least hahaha.
I had 4 molars removed aged 12 when I had my removable braces and one wisdom tooth removed only 6 months ago. Plus 15 years ago I had one molar removed due to an abcess. That leaves 3 teeth unaccounted for :? Maybe not all my wisdom teeth came through.
Lozzie83
#15 Post by Lozzie83 »
I have 24.. I had 4 wisdom's and 4 pre molars removed three weeks ago
