well got my extractions
Killaking
#1 Post by Killaking »
I got 2 teeth (first biscuspid) pulled today so they can move my bottom teeth back i hope they got the right ones lol does your bottom teeth look right after extractions and they move they do the back teeth and the fronts move together or do the just move the front teeth back anyone got any pics to show the before and after? and when people get teeth taken out is it the teeth i got taken out today that are sometimes the first to go? oh yea and it cost me 5 dollars lol[/quote]
adultbraces
#2 Post by adultbraces »
($5) sounds awfully cheap. Did you have to go to a oral surgeon for that?
As far as the movement of your teeth, your ortho should tell you different option of treatments if there are any choice for you to choose. If not , you can always ask..
Killaking
#3 Post by Killaking »
adultbraces wrote:($5) sounds awfully cheap. Did you have to go to a oral surgeon for that?
both my parents are nurses so we have great insurance even though it doesnt cover braces but when they close the gaps will my teeth be gapped?
Chris1960
#4 Post by Chris1960 »
Is the 1st bicuspid the one in front or the back? I had the back ones removed though it seems to me it would have made more sense to remove the front ones.
They told me that I was going to get posts (screws/taps?) put in to anchor the chains for closing the gap.
The extractions were my favorite part of the whole process so far. They twilighted me :-Z which is always fun plus I got vicodin :crazy: .
