Metal Bands digging into my gums?
There's no way around it, I have short teeth. This means less space for my braces. I've known they've been digging into my gums for a long time, but it's just now starting to bug me. I'm terribly nervous for the pain associated with this while getting debanded (in a year). Has this happened to anyone else? My orthodontist has seen it but doesn't say anything about it. Help!
Braced on January 5th, 2007
Debanded on April 2nd, 2009
Click www to see my story!
AstronautJenny,
I had the same problem on one side. I figured it out to be a loose molar band and each time I would eat something it hurt. I found out that it was a loose band, so I called my orthodontist and asked if I could remove it myself and cut the wire. I only did this because he is 280 miles away. Another reason I removed it was that it can cause decay extremely quick if the glue has broken loose.
Here is a link:
http://www.conroebraces.com/emergency.html
Here is a link:
