Now a have a gap between my teeth? Is this normal?
ljandersmith
#1 Post by ljandersmith »
Today after lunch I noticed I had a very noticeable gap between my two front teeth. I have never had this before and my ortho is closed....Is this normal, it doesnt seem right???
thanks
Gennel
#2 Post by Gennel »
Teeth move are shifting constantly througout treatment. When I started mytreatment I had no gaps in my front teeth but after like 2+ months I had a really big gap in myfront teeth :( It really bothered me but it did close up again within a month or so.
Gennel
platinum
#3 Post by platinum »
normal....
I developed three gaps between my front laterals...
They will be closed by using powerchains.
Lisa65
#4 Post by Lisa65 »
It can happen, but powerchains will close it up in no time, once you get them.
BracedUpG8rGrrl
#5 Post by BracedUpG8rGrrl »
This happened to me too. About a month after I got braced, I noticed a gap that opened up. When I went back for my first adjustment, the ortho put on a powerchain and it closed up in a couple of weeks.
My ortho mentioned that this may happen a few times in the course of treatment, but told me not to freak out, everything would be in the right place in the end. So far, he hasn't been wrong. :)
Christy
Megan89
#6 Post by Megan89 »
I had a pretty big gap between my front big tooth and the one next to it, it was about 1mm wide. Within 6hrs of a powerchain being on the gap was closed. I was so shocked! My front teeth are so tight now! It's getting hard to floss.
Boolajoojoo
#7 Post by Boolajoojoo »
I've had a couple of gaps open up and close all on their own inbetween adjustments. The ortho's never mentioned power chains or anything because I haven't had the gaps at any of my adjustments. I guess I would probably make a phone call if I had teeth that were rapidly drifting waay far away from each other...
ljandersmith
#8 Post by ljandersmith »
Ironically enough My gap closed the next day! Its so random how your teeth move everyday!
sean83
#9 Post by sean83 »
Does everyone get power chains? Will he just surprise me with them at an adjustment?!
platinum
#10 Post by platinum »
My upper teeth got gappy and I got powerchains on my top teeth. The ortho said that my lower teeth do not have gaps, so i wont need a powerhain there.
lauren321
#11 Post by lauren321 »
I've been braced for 2 weeks and I have a mm sized gap already. That tooth seems to be moving faster than the rest.
