dentist says i should get cleaning every 3 months
So my dentist says I should get cleanings every 3 months now because I have braces and apparently teeth with braces need more cleanings?
Are you getting your teeth cleaned more often now that you have braces?
After my first cleaning with braces, my dentist suggested that I come in every 3 months, because I wasn't doing a good enough job of keeping my plaque under control - I was a little plaque factory!
I did get my teeth cleaned before my braces went on, first cleaning with braces 6 months after that, then second cleaning 3 months later. At the second cleaning, it appeared that I had learned at least part of the lesson on how to keep my teeth clean with braces. After that, I went every 4 months while I had braces on.
So, my advice is - wait until your first post-braces cleaning. That will give you (and your dentist) a better idea of how well you are cleaning with braces.
I've just had to cancel my cleaning appointment as my teeth felt so sore and tender - couldn't BEAR to touch them with my tongue, let alone have some gung-ho hygenist prodding and scraping and scratching about in there.
But I know I'll have to go at some point soon. Just a matter of timing it so my teeth are "resting" rather than on the move.
In the brochure I got from ortho's office they also recommend that adult's get teeth cleaned every 3 months (teens/children every 6 months). I've found that I need the clean every 3-4 months as I drink too much tea and my teeth stain from that. I have been cutting down (reluctantly
) and the dentist feels that 6 months may be OK for next visit, time will tell.
2 upper 1st bicuspids extracted
Uppers braced (metal), molar bands upper & lower 25 May 07
Lowers braced 22 Oct 07
Next adjustment 21 Apr 2008
Estimated brace time 2.5 years
I went to my first post braces cleaning and they still recommended every 6 months for me. My ortho also scrapes away some of the plaque build up on my lower 6 when he sees any build up but he has not told me to go for cleanings more often. Past few adjustments he has not scraped any plaque nor has he told me to brush more often.
Est. term: 30-36 months
My hygienist said there was virtually nothing for her to do last time I went, and that it was up to me if I came back in 6 months, or just if/when I felt the need. I'm going to stick to 6 month visits though, just to keep my teeth as clean as possible.
Admittedly I do not tend to accumulate tartar so I'm lucky. Some people are more prone to it.
If you take good care of your teeth, I don't think you should need a cleaning more often than every six months.
I have had had braces for 2 and a half years, and I have only had one cleaning in that whole time. I don't have any insurance, and I am paying for the whole braces thing out of pocket, and I just couldn't afford it.
When I had my check-up/cleaning, everything was fine. But I am glad that I went, because the dentist spotted a band that didn't fit well, and it was catching food, and he said it could lead to decay. Apparently my ortho never noticed it.
Yeah, count me as one that doesn't think the 3 month interval is mandatory. I had my first 3 mo. post braces cleaning yesterday. And I don't think I'll go again for 6 mo.
I think if you are good about brushing/flossing and occasionally using a metal pick of your own you'd be okay to go 6 mo. Make sure you brush your gums - I forget why, but it sounded important.
Brackets off 6/5/08
Invisaligns on 7/28/08
(7 Week delay)
21 of 23 U&L (Skipped a tray/On a 10 day rotation)
Class II subdivision right
Moderate upper/lower crowding
Partial anterior crossbite
Normal overbite/overjet
Sentence: 18-20 months
I was told by my ortho to have my teeth cleaned every 4 months, instead of 6. I already made an appointment. I'm just wondering how they're going to floss around the braces? It always hurts when they've flossed without braces. I can't imagine how bad it'll be WITH braces!
I know I've been flossing with the threader every night and so far it's been pretty painful. There's some teeth I can't even get between that I used to be able to floss. The ortho did tell me that would happen, though.
My ortho says everyone must get their teeth cleaned every three months while in braces, and the 3rd and 9th month cleanings should be done with the wires off.
I'm going to do it, because I can afford it and I don't want to risk gum problems, while I'm already taking the unavoidable risks of braces.
Some people seem to need more cleanings than others - for a while when I had no dental insurance, and before braces, my regular dentist agreed that once every 12 months was okay for me, because I don't have a lot of tartar build-up and my gums are healthy. But my husband really has to have his done every 6 months, even though he is fanatic about flossing, brushing, etc., just because of his mouth chemistry.
Re: dentist says i should get cleaning every 3 months
No, I am not, I get three cleanings per year as I build up plaque quickly says my dentist. Unfortunately, my insurance still only pays for two of themSo my dentist says I should get cleanings every 3 months now because I have braces and apparently teeth with braces need more cleanings?
http://bracesafter40.blogspot.com
Bridge Sectioned: Feb. 14, 2007
Last Pre-braces cleaning: Feb. 20, 2007
#21 Extraction: Feb. 20, 2007
Sentenced: 32 months
Top Braced: Feb 28, 2007
Bottom Braced: Apr. 4, 2007
New Ortho on Apr. 25, 2008
May 6; fluorescent blue ligs incl. upper powerchains. 2 elastics; Sept. 2, 2008.
Next Adj.: July 7, 2009 at 8:30a
