Hi all
I'm hoping somebody will know the answer to my question. I need to get a filling done (not to happy about this as it will mean a trip to the ortho for bracket removal, trip to dentist for filling, trip back to ortho to get bracket put back on), however I have no choice as it needs doing.
My dentist can't fit me in for the filling until April 17th. What I'm wondering is if it is possible for a cavity to grow and grow rather quickly between now and April 17th or am I worrying for no reason?
Regards
Joney
How quickly can a tooth decay?
Brace On 10th November 2006
I'm sure you'll get alot of varying answers, but it is certainly possible for decay to stop.
I have cavity in a wisdom tooth that is in arrested decay. It doesn't hurt me ever and when the dentist poked it she said it was not soft. We are waiting for the tooth to be pulled up a bit before she fills it.
I think if you maintain very good hygiene you should be okay.
I had a "mystery spot" on a tooth that my dentist was keeping an eye on for almost 2 years before he decided that it really was decay and not just a stain as he had originally thought. Even after that long, it was still just a tiny spot of surface decay that had barely went through the enamel. I had it filled with no novacaine and I didn't feel a thing. Even after all that time it hadn't penetrated deep enough to do any real damage. Don't worry. You'll be okay.
It also depends. I'm getting fillings tomorrow (3, ew) and they said they are just on the surface so they do not need to remove the brackets. I'd double check. But if you use flouride rinse and really take care of your teeth you should be fine. I had to schedule mine for weeks from when they first found them and they weren't worried about me putting them off.
