Infected wisdom tooth site =( Help!!
So ive been having this gross smelling/tasting stuff fluid coming out of one of my bottom wisdom teeth extraction sites so I have an appt today to get it checked out....what are they going to do if it is infected?? What is the basic procedure for something like this? I am nervous =( I dont want to do this anymoreee lol
You will be fine. You might have something stuck in the hole in which case it will need a clean out, or maybe a piece of bone chip is working its way out and has set up an infection, or maybe it's just bad luck. A course of antibiotics will sort you out
Try not to stress too much. It's not that uncommon to get an infection after extraction. Our mouths are full of bacteria.
