ortho forgot to put lig on
Killaking
#1 Post by Killaking »
he forgot to put the lig on in one of my bottom teeth the one after my gap in my extraction is this a big problem or not i have my next appointment in may.
hank hill
#2 Post by hank hill »
maybe he couldnt get it on. when i first got my braces they couldnt get it on some teeth because they were too crooked.
suetemi
#3 Post by suetemi »
He may have done it on purpose, maybe? My ortho did stuff with my brackets and ligs on purpose that puzzles me , but since he's the professional with 20 yrs experience I assume he knows what he's doing. Not that I'm saying your ortho isn't capable of oversights or small errors like forgetting a lig, but it's likely there's an explanation to why he did something. My ortho is good in that he'll explain everything he's doing, particularly if it's something he anticipates me asking about later.
4113n
#4 Post by 4113n »
a forgotten lig is not that much of a problem, learning it the hard way by bothering so many people. =p
Betty Bat
#5 Post by Betty Bat »
If you have a question like that, it's worth it to give your ortho a call. We can speculate about your case, but your ortho will know exactly if it's a problem or not.
P.S. I had a Damon door left open accidentally once and it started to irritate my lip. When I called and told them about the problem, I was in there the next day to get it fixed.
Killaking
#6 Post by Killaking »
Betty Bat wrote:If you have a question like that, it's worth it to give your ortho a call. We can speculate about your case, but your ortho will know exactly if it's a problem or not.
yea i was just asking because he is on vacation for spring break
DireWire
#7 Post by DireWire »
Not that it makes much of a difference, but it could also have popped of by itself. Happened to me recently.
He's close to my office, so I just stopped by and got it fixed. They used now ligature wire which is more stable.
DireWire
Bite plate gone for good after @3 mths
