I am new here, planning on getting braces soon. I know I should ask my ortho, BUTTTTT! I am impatient. : )
I have a lower molar thats tilted in, its crowned and root canal'd. Is iy possible to move a tooth like that? I needs to be tilted up and out a bit, but I am betting it can't be moved. : (
Anyone have a tooth like that, that was moved???
Thanks guys/gals!
Possible to move a root canal'd/ crowned tooth?!
happyhappyjoyjoy you already posted about this and people have replied. Don't forget to check threads that you have posted about the same topic as you may already have responses.
viewtopic.php?t=25178
Est. term: 30-36 months
I had a very tilted molar and it was moved.I did not have a crown on it ,however i do have a HUGE filling in that molar.They will most likely put a molar band on that molar then either try elastics first to move it upright. If that does not work after a few months then they might use an expander which adds more force than an elastic would. it took like 7 months with an expander to move my tipped molars upright but they did it and I thought it would be impossible since mine were the most tilted molar case he has ever had! He told me this after my molars were finally upright. I guess he didn't want me worrying and doubting that it would work...
Gennel
Gennel
