Wire ties
Wire ties
Do you think that any ortho can offer wire ties? I didn't ask mine about those - but I plan to. Also - he has assistants that change the ligs - well i wonder if wire ties are able to be changed by an assistant or if the ortho has to do it since it isn't like the wire ties are premade right? They need to be put on and twisted and it would seem that the tightness could vary vs. actual rubber ligs.
yeah the assts can do wire ties. i got them right now and ive had both. your first month or so tho, i dont recomend the wire ties. they are less noticable, but dont cushion the lip or bracket like the rubber ligs. you will find the rubber ligs much more comfortable in the beggining. wire ligs make the brackets much sharper, something you dont really want in your first month. just my thoughts.
SuperDave
SuperDave
braced 1981-1983 all metal
braced again 8-30-2007
ceramic on top, metal on bottom
started rubber bands single triangle pattern 1-08
started double trinangle pattern 3-08 (yes 4 of them 2 each side) !!!!
power chains on top 6-12-08
still double triangle. geez!
top ceramics changed to metal april 01, 2009
may 14, 2009,....finally no rubber bands
(well for now anyway)
next apptmt. is july 8th, 2009 2:00pm
Yes, this is very true. But I like the wire ties much better because they don't stain at all, unlike my clear rubber ligs. Also, my ortho wouldn't let me wear wire ties until all the spaces closed on my upper arch. I never asked why all the spaces needed to be closed before I could sport the wire ties, but maybe someone else on the board can provide some insight.wire ligs make the brackets much sharper, something you dont really want in your first month.
My orthodontist explained that wire ties are used when he wants a tooth to NOT move in order to accomplish whatever he is doing at the time. I have a few wire ties and I have really never felt them. If they are poking, it seems like it would be easy to bend in the end or something, the wire is very thin.
Kaycee
Kaycee
I have always had wire ties, and have had no discomfort other than once when the end came a bit untucked - took a second to fix with the hook you use to put on your elastics,no bother. I have gaps that are being closed so maybe my ortho wouldn't agree with the poster above, when I asked about wire vs. rubber he said the wire ties are faster and stay firmer than the rubber.
Ive had ligs for all of my treatment up until surgery and then they put wire ties on all my teeth instead. I much preferred the ligs as the ties seemed sharp and pointy even when the ends were pushed in. I had the wire ties taken off on thursday and i was very happy to get my ligs back! Thats just my opinion tho.
I had wire ties during the beginning phases of treatment, and quite often throughout the rest. My ortho said in the beginning it was necessary, my teeth needed the strenght of wire ties to attatch to the archwire because of my "issues". Later, I was able to get lots of colour, but often have had wire for various reasons. Right now I am in a wire~tie power chain. Wire ties wrapped and criss~crossed accross the front 8 brackets on both arches. Very tight and my teeth aren't going anywhere!!!
YaaaaaY to me for the settling phase!
I've always had wire ties so cannot compare..but I don't have an abnormal amount of discomfort, in my 6 months of braces (though admittedly only lowers so far), I used wax on my brackets for the 1st two days. Every few weeks my cheek gets cut up where there's an edge of a wire tie, but I just tuck it in under my archwire.
Actually, I have had two elastic ligs but probably not enough of a basis to compare.
Hi Beth,
I'm sure that your ortho offers wire ties. He must use them on his patients sometime during their treatment. I didn't mention anything about wireties until the assistant was going for the ligs on installation and I mentioned that I was a coffee drinker and she didn't see it being an issue and then she asked the ortho just to make sure and he said no problem. I had silver ligs on the lowers since that they're metal. I had the same ties from the beginning and yesterday during my upper wire change, I'm sporting a new set of wire ties.
I did get a lower powerchain yesterday and was looking at the colors (almost went for color, but I wasn't daring enough, maybe next time) I might have to go with color b/c they had clear (which I would be nervous about with staining) and some light shades as well, staining is an issue, silver would probably my best choice, but I'll cross that bridge when the time comes.
Just call the new patient coordinator and ask about the wire ties.
Catch ya later.
B
Catch ya later.
B
I would clearly expect that you can get wire ties if you prefer, and any assistant should be able to put them on.
I actually have a mix of wires and ligs. I have wires in places where:
- the crowding is so strong that the archwire doesn't even come close enough to the tooth to be put into the bracket, so you have to pull the distant tooth in via a wire sling
- elastics aren't strong enough to hold the archwire. In one occasion an elastic popped within 24 hrs because the tension was too strong or maybe due to cleaning. Anyways, it was replaced by wire ties which are more stable.
I don't really care what they put on. Either way is fine for me, and so far, progress has been great and visible. But I think they would be able to accomodate a preference if I had one.
DireWire
DireWire
Bite plate gone for good after @3 mths
My roommate in college had wire ties because she had too much trouble keeping her teeth clean with the colored ligs. I have heard the ligs are more bulky or something.
Personally, I have no experience because I have self-ligating braces. Sometimes though, I dream of the fun colors everyone else gets to have
<img>
I always had rubber ligs from the beginning but then I started having problems with the coloured ones on the bottom breaking only a few weeks after being put on. My ortho thinks it's probably to do with rigourous cleaning! So to save the inconvenience to us both of me going for interim appoinments between adjustments just to change the ligs, he's now put wire ligs on the bottom.
I don't mind them, they're not too scratchy because the ends are tucked in nicely. But does mean no more colour!
