Can an adult use an expander of some sort?
Can an adult use an expander of some sort? I really hope so. I noticed my cheeks have sunken in after extraction and shaving so I hope there is something I can use to re expand my jaw... Let me know thanks.
Yep
Im an adult and I have an expander. It was the alternative to jaw surg to correct an overbite. It hasnt been that bad and from looking at my pre-braces pics I can see it was worth it.
Fingers crossed for March 2009 - braces come off!! I have expander, top and bottom braces and bands.....you name it, i got it.
I'm 36 and I have a RPE (non-removable). I was concerned that it wouldn't work in an adult without surgery, but I have been told it will. It's only been in for 2 weeks, so I can't say I've seen much difference, but some of my friends say they can see a change in my face. I have to continue to turn the key for 6 more weeks, then it will remain in place for an additional 2-4 months for everything to stabilize. I must tell you I truly hate this appliance, but I have confidence the results will be worth it.
I have an expansion screw in my upper removable brace - my ortho says it will tip the teeth outwards (which is fine, as mine need tipped a little), but also expand the arch a few mm which I also need. I think some of the thinking that expanders don't work in adults without SARPE is older thinking, as I've read of a few people on here who have had them successfully without any surgery. Or maybe it goes on a case by case basis, who knows? Not me!
If you have the choice, I would pick a removable expander, I know that a lot of people have had trouple with speech and/or eating with fixed ones. Nothing unsurpassable, but I just like to be able to take my tops out and eat away!
I've heard expansion doesn't work in women over 16 and men over 18. But there are definitely a lot of doctors who believe it does, or at least try it. I had to wear an upper non-removable expander twice during my treatment. I think it must have done some good, although I still ended up getting 2 bicuspids pulled.
Yes, adults can have expanders but I have to say I'm not convinced that this would necessarily provide an answer for sunken cheeks.
I had SARPE and wore an expander for over 6 months. This has widened my palate as intended. I have also gained cheekbones with very slight hollows under them which I never had before. This isn't a problem for me and I'm nowhere near done with treatment yet anyway, but I just thought I'd better throw that in to the debate. Not wishing to spread gloom and despondency, but just to advise that an expander won't necessarily solve the problem...
