When going for your first adjustment.......
What can I expect? Is it common to get a new wire? How are adjustments done? How often would I get a new wire? When I go I will find out what kind of braces I have. Unless I can steal the digital camera from my wife for a few minutes and post pics online for you guys to see. Whatever I have the wire snaps into the braces. Help this newb understand what to expect on my first adjustment.
hi
at my first adjustment I had a new wire , but had had a molar band added so needed a longer one
. I think that often all that is done is that new ligs are put on ... which I find uncomfortable on some teeth ..... till a stronger / different action wire required.
I find the pressure kicks in the day after and is variable at times between adjustments.
I have not needed to take any analgesia so far ....... but am only 7 1/2 weeks in
I suppose what happens will vary according to what is needed for your teeth ..... some folk need elastics or powerchains , some folk like yourself dont have ligs ( if the brackets self closing ?????)
After the first adjustment
After the first adjustment it was a little uncomfortable, as the ortho added a power chain to the top teeth. There was some tightening going on, but it was nothing that a couple of ibuprofen couldn't handle.
I look forward to the adjustments. Every adjustment means I'm that much closer to the final result!
- Bill
- Bill
