That was exactly my fear in my case, too. I had 2 upper premolars extracted to correct an overjet, sometimes my ortho says that he thinks he can close it, sometimes he told me there might be a 1mm gap. So I used to ask him do I need to have my lower shaved a bit to make room, and he says it's possible. Anyway, I think I always get contradicting answers from him, and never absolute:(
So have you asked your ortho if shaving the lowers is an option? from what I've heard, you can make at least 3mm (0.5mm (0.25mm x2 sides) x 6 teeth) out of it, maybe even more. From what I've heard about bonding, it's usually done on the front teeth, do you know if you can also do it for the molar? Anyway, I'll try to ask more about it on my next appointment, which is still 3 weeks away
But I'll keep you updated. Please also let me know if your ortho propose any solution for this. BTW, how long did it take you to close your gaps? I mean after all the teeth alignments were done and from the ortho start to pull the front teeth back (say put on power chains and stuff)
