Bracket Repositioning...
dimplez23
#1 Post by dimplez23 »
I just went in today for my 6th month check up and adjustment. All that I had done was changing of my ligs but then the ortho told the assistant to take me to get x-rays. I asked her what this was for and she said that it was to find out if my roots where in their correct positions and if they werent then on my next adjustment (Aug. 12) I would need my brackets repositioned. Question: What exactly is done in this process and how long does this take? I hope someone can help...Thanks in advance....oh yeah good news..if i dont need repositioning then they will start to close my gaps!!!! yay!!!!
2/26/08- 4 spacers & brackets
3/4/08- 4 molar bands & 8 spacers
3/8/08- 4 premolars pulled
3/11/08- WIRES put on!! Ouuch! & 4 more molar bands
3/18/08- TPA put on and a lower lingual arch Torture Time -30 months
Next adjustment: August 12th
Last adjustment: July 16th
lionfish
#2 Post by lionfish »
They remove selected brackets and place new ones in different positions. If your brackets are all metal, they should snap off easily. Ceramics can involve a little more work. The placing of new brackets is no different to what would have happened when you first got braces.
dimplez23
#3 Post by dimplez23 »
Thanks lionfish! I was just wondering because I didnt really know what the process was...I kinda figured they would move the brackets around but I didnt really know what exactly they would do.
purpleteeth
#4 Post by purpleteeth »
It sounds painful... but I sure hope my ortho does x-rays and finds out the condition of my roots. I want to REALLY know how things are progressing.
<img>
Lisa65
#5 Post by Lisa65 »
It's not painful, purpleteeth. I've had a couple of brackets repositioned and the only horrible bit was having the old glue ground off my teeth before my ortho put the bracket back on.
married2abuckeye
#6 Post by married2abuckeye »
I had 2 brackets repositioned once, and all the Ortho did was take this little device that looked like little pliers, and kind of pinched the brackets off. They just popped off. Then as Lisa65 said, the worst was getting the glue sanded off. Oooh, and then getting the teeth re-etched.:yuck: Yucky taste! But, the whole ordeal took just a few minutes or so.
Anyway, good luck!
Follow my metal-mouthed journey here
dimplez23
#7 Post by dimplez23 »
Thanks everyone for the informative posts! I hope that I don't have to have that done so they can start closing my gaps....but of it has to be done then ill be ok with it!
