pre-braces going on ????
shan*rock
#1 Post by shan*rock »
I'm just wondering if the ortho cleans your teeth before putting the braces on. I'm particularly interested because I currently have spacers and I feel like so much junk is getting stuck around them.
Can anyone fill me in on their experience? Thanks!
mkvkelly
#2 Post by mkvkelly »
There was a lot of food stuck in mine, it was gross! I just asked my ortho if I could brush my teeth once they had taken my spacers out. I'm not too sure if they actually cleaned mine I don't believe they did. But you can always ask to brush/floss etc.
janessa
#3 Post by janessa »
Generally, the ortho does not do dental cleanings. I have read that it is a good idea to go to the dentist for a bi-annual cleaning before you get your braces put on. I had spacers and tried to do this but got cancelled at the last minute, so I got braces right before I had my 6 month checkup/cleaning, and it was no big deal. As far as cleaning around your spacers goes--get a WaterPik and seriously blast the area. Believe me you will want to have one when you have braces anyway.
shan*rock
#4 Post by shan*rock »
Good to know, thanks mkvkelly and janessa. If they don't ask me if I want to brush after the spacers come out I will make sure to ask if I can.
Janessa, I picked up a waterpik last week and have used it a few times, but I've been a little bit afraid to ever since these spacers got put in. I didn't want to make one pop out, but I guess that's not very likely to happen from a Waterpik right?
purpleteeth
#5 Post by purpleteeth »
I didn't have time to get my teeth cleaned before my braces went on, but they said it wasn't going to be any problem at all --- as they were going to do a little bit of cleaning on the surface of the teeth before they put the brackets on.
You can always just schedule yourself a cleaning with the spacers in I suppose, jsut to be on the safe side.
<img>
Miranbrady20
#6 Post by Miranbrady20 »
they had me brush and floss my self before we did anything and after the spacers were out!!! now i was wondering how to floss the teeth with molar bands on... i guess you cant huh?
NYG2007
#7 Post by NYG2007 »
They put this paste on my teeth before and had me rinse before they put the braces on. This is a standard practice at my otho. It was kind of grainy paste, so they have the patients floss before the braces go on.
Braces worn for 2 Years 4 Days
Blog: http://nygbracesjourney.blogspot.com/
