Tooth sensitivity
Tooth sensitivity
Ok I did a little search and found a lot but not what I was looking for. I am power chained from 3-6 on top and bottom and both sides. For some reason 2 days ago I woke up and just out of no where my right upper canine tooth was extremely sensitive to anything cold. Cottage cheese, yogurt, water or anything. Is this something that I should be considerably worried about? I have my next cleaning at my dentist next Tuesday and don't know if I should just wait and see what happens between now and then or what. A little nervous and scared to be honest.
I had my last adjustment 10 days ago with IPR on my uppers and I have a powerchain from 6-6 and an additional zing string from 3-3. I definitely experienced sensitivity for the first time and started using sensitivity toothpaste and it seemed to help. I probably added insult to injury by having a cleaning the same day.
B
B
I'v always had really sensitive teeth even before i got my braces so you can imagine how worrid i was about getting sensitive teeth once the braces come on. When i had my sensitive teeth issue before my braces, my dentist recomended that i start using sensodyne. it seems to have taken the edge off of the sensitivity. so you could perhaps try something like that. I still do get sensitivity but i'm convinced that if i didn't start on the sensodyne i would probably be a hole heck of a lot more sensitive then i am today.
Braced: March 19th 2008
