how long does it take to put on the INman aligner
rachelluang
#1 Post by rachelluang »
I am thinking to use inman aligner to straighten my teeth!
for the ones what had put it on, who can tell me how long do i have to wait for putting on after the decision>
Cheers
jodiejo
#2 Post by jodiejo »
Hiya, normally you would have to be recommended for one by your dentist. He would then take impressions from your teeth and then it is normally about 3 weeks before you actually get the IA. Once it is ready, your dentist may have to "file" your teeth slightly for the IA to fit and start working - this is NOT as scary as it sounds believe me as I am terrified of the dentist and it was fine getting this done.
Your dentist will then show you how to put it in and out and make you do the same just make sure you are comfortable with it and then that is all there is to it, all done and dusted!!!
Good luck if you do decide to go for it - best decision I made - have a read at the Innam Aligner thread further up the forum.
TeacherK
#3 Post by TeacherK »
Hi this is a question about the Inman and other removeable braces. Are they all just for the upper teeth or can you wear them on upper and lower at the same time?
Cheers
